[SOLVED] Dell Vostro 14 -5459 heat upto 80 degrees and then suddenly throttle causing massive fps drops. Please need assistance!
saad1118
4
After hitting 80 degrees the cpu just throttles to 398 Mhz from the 3090Mhz and after exactly 5-10 secs, it goes up again. What is the solution to this? I'm using a dedicated laptop cooler underneath. The gpu and other components have ideal temps.
There really isn't anything TO do, assuming you have already cleaned dust and/or gone in and repasted the cooler. The Vostro is a budget class laptop, probably never envisioned "gaming" beyond some minesweeper or solitaire.
