Difference between Asus Z170 Pro and Pro gaming
RedDevil965
Commendable
Nov 27, 2016
6
Hi, i'm looking to build a pc and can't decide which one of the two should I get as I'm not sure about any major difference between the two, I'll have the i5 6600k and a rx 480 and will be gaming only and also overclock the CPU.
Is there any major reason why I should spend 40$ more and get the z 170 Pro or will I be fine with Pro gaming?
The Asus Z170 PRO GAMING Has LGA1151 socket for 6th Gen Intel® Core™ Desktop Processors
Dual DDR4 3400 (OC) support
PRO Clock technology, 5-Way Optimization and 2nd-generation T-Topology: Easy and stable overclocking
SupremeFX: Flawless audio that makes you part of the game
Intel Gigabit Ethernet, LANGuard & GameFirst III: Top-speed protected networking
RAMCache: Speed up your game loads
USB 3.1 Type A/C & M.2: Ultra-speedy transfers for faster gaming
Gamer's Guardian: Highly-durable components and smart DIY features
While The Asus Z170 Pro Doesn't
I Hope This Solves Your Issue.
