Difference Between DDR3 And GDDR3 ?
hashim1991
88
I was searching and found that some cards are DDR3 and some are GDDR3 , so whats the difference ?
for example out of these which version is better ?
Sapphire Radeon HD 7790 1GB DDR5 DL-DVI-I/DL-DVI-D/HDMI/DP PCI-Express Graphics Card 11210-00-20G
http://www.amazon.com/gp/product/B00BWHIOVW/ref=s9_psimh_gw_p147_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1K6674VCEPMPRDYGA76F&pf_rd_t=101&pf_rd_p=1630083462&pf_rd_i=507846
ASUS HD7790-DC2OC-1GD5 Radeon HD7790 1GB GDDR5 128-bit, DVI-I/DVI-D/ HDMI/DP PCI-Express 3.0 CrossFire ready Graphic Card OC-selected 1075MHz core
http://www.amazon.com/gp/product/B00BZCXZ0E/ref=s9_psimh_gw_p147_d0_i3?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1K6674VCEPMPRDYGA76F&pf_rd_t=101&pf_rd_p=1630083462&pf_rd_i=507846
I answered your question.
First of all you said "DDR3" and the link said "DDR5" at the top and "GDDR5" next to the card so I'm not quite sure where you got the "DDR3" idea.
DDR3 is issued on some low-end video cards that don't require fast video memory.
GDDR5 (not GDDR3) is used for most video cards.
BOTH cards you linked use GDDR5 video memory.
Here's the official link for the Sapphire: http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1159&pid=1875&psn=&lid=1&leg=0
The ASUS HD7790-DC2OC-1GD5 is the better card.
It's a spelling mistake, the two forms of ram are DDR3, used in memory ram and GDDR5, used in GPU ram. Except the PS4 is using DDR5, never seen before. And get the Asus. (Try getting MSI cards if you can with their Gaming OC Edition, they're cheap, easily overclockable and kick ass)
