[SOLVED] Difference between LED's in Corsair SP120 RGB Pro and RGB Elite?
I BIN A RADLA
Commendable
Dec 10, 2020
15
I currently have 3 corsair sp120 rgb elite which came preinstalled with my case and I'm thinking about buying three more fans and i'm wondering if the leds are different between the corsair sp120 rgb elite and rgb pro
The pro's have a higher starting operating voltage and lacks PWM control, the elite is 2db louder but weigh less than the pro's and have a slightly higher static pressure while having lower cfm than the pro's all while being PWM capable.
Info was found from these two links;
https://www.corsair.com/us/en/Categ...RO-Performance/p/CO-9050094-WW#tab-tech-specs
As for the LED question, they look the same;
View: https://www.youtube.com/watch?v=-74FIVBmWEI...
