Difference between these two Asus? Help please
JJ2012
174
What is the the difference apart from price, between
ASUS Z87-PRO Socket 1150 4xDDR3 Max 32GB ATX Intel Z87 PCI-E 1x D-Sub DVI HDMI DisplayPort
and the
Asus H87M-E micro atx LGA1150?
Trying to decide which to go for.
Thanks.
ASUS Z87-PRO Socket 1150 has more components than the Asus H87M-E micro atx LGA1150.
It is better as well.
You should go for ASUS Z87-PRO Socket 1150.
Great thank you.
Which psu would be better
Corsair Builder Series CXM 750W Modular 80 PLUS Bronze Certified ATX/EPS PSU
Or
Corsair Professional Series AX 760 Watt ATX/EPS Fully Modular 80 PLUS Platinum Power Supply Unit
They are both good. I would say go for the second one because of its reliability.
