fzabkar :
If the maximum transfer rate is being throttled by the SATA interface, then you should see a long flat 150 MB/s plateau at the outer zones. The minimum transfer rate would still be 90 MB/s, though. The burst rate should correspond to the interface limit.
This thread discusses the DCM (Drive Configuration Matrix), at least for older WD models:
http://forum.hddguru.com/western-digital-what-dcm-t6488.html
It seems that the 5th and 6th characters identify the Media type and Headstack, respectively.
Interesting results...
SiSoftware Sandra
Benchmark Results
Drive Index : 124.27MB/s
Results Interpretation : Higher index values are better.
Random Access Time : 16ms
Results Interpretation : Lower index values are better.
Performance vs. Speed
Drive Index : 17.67kB/s/rpm
Random Access Time : 0.002ms/rpm
Detailed Benchmark Results
Speed at position 0% : 72.69MB/s (49%)
Speed at position 3% : 148.73MB/s (99%)
Speed at position 7% : 147.01MB/s (98%)
Speed at position 10% : 108.09MB/s (72%)
Speed at position 13% : 144.06MB/s (96%)
Speed at position 17% : 146.89MB/s (98%)
Speed at position 20% : 142.68MB/s (95%)
Speed at position 23% : 141.21MB/s (94%)
Speed at position 27% : 140.96MB/s (94%)
Speed at position 30% : 106.96MB/s (71%)
Speed at position 33% : 133.55MB/s (89%)
Speed at position 37% : 138.03MB/s (92%)
Speed at position 40% : 133.41MB/s (89%)
Speed at position 43% : 135.23MB/s (90%)
Speed at position 47% : 136.59MB/s (91%)
Speed at position 50% : 100.07MB/s (67%)
Speed at position 53% : 133.40MB/s (89%)
Speed at position 57% : 128.73MB/s (86%)
Speed at position 60% : 127.93MB/s (85%)
Speed at position 63% : 138.31MB/s (92%)
Speed at position 67% : 123.68MB/s (83%)
Speed at position 70% : 89.98MB/s (60%)
Speed at position 73% : 125.25MB/s (84%)
Speed at position 77% : 116.56MB/s (78%)
Speed at position 80% : 114.88MB/s (77%)
Speed at position 83% : 119.39MB/s (80%)
Speed at position 87% : 112.10MB/s (75%)
Speed at position 90% : 112.53MB/s (75%)
Speed at position 93% : 115.77MB/s (77%)
Speed at position 97% : 112.74MB/s (75%)
Speed at position 100% : 104.96MB/s (70%)
Full Stroke Access Time : 8ms
Performance Test Status
Run ID : WDC WD5003AZEX-00K1GA0 500GB (SATA600, 3.5", NCQ)
Platform Compliance : x86
System Timer : 3.40GHz
Use Overlapped I/O : Yes
I/O Queue Depth : 4 request(s)
Block Size : 1MB
Volume Information
Capacity : 465.76GB
Physical Disk
Model : WDC WD5003AZEX-00K1GA0
Version : 80.00A80
Interface : SATA
Removable Drive : No
Queueing On : Yes
Not 100% sure what this benchmark can tell us but I'm happy to hear your theory.
