[SOLVED] Difference in thickness between two cards
Xperier
Commendable
Jun 5, 2017
11
Probably a dumb sounding question but what would be the difference in the thickness between the two cards 'Gigabyte GTX 1050 Ti Windforce' and 'EVGA GeForce GTX 1660 Ti SC Ultra Gaming'?
I was looking up the specs to check the sizes as I'm looking to upgrade to this card but the size is a real issue as my current card (the 1050 Ti) is VERY close to touching my wifi card. The only card that showed an exact measurement was the 1050 Ti, which the card pokes out a little, with it being 40mm whereas all the specs I've looked at for the 1660 Ti only say that its 'dual slot'.
Does this mean the 1660 Ti is exactly the size of two slots or does it poke out a little?
Thanks!
