Question Different types of BSOD's on turning on the laptop (is it water damage need help)
Dec 30, 2018
13
Guys my laptop was kept beneath my AC and my AC was dripping water drops from the front I don't know why , my laptop is Lenovo y520 , when I picked it up water poured out a little from the right external speaker , and from that point on I've been getting different BSOD's like :-
'Unexpected store exception'
'Bad system config'
'Critical process died'
After bad system config I think the laptop went into automatic repair , turned on then froze again , it always freezes as I open it up in the next few seconds.
And even the BSOD's screen gets stuck at 0%
NOTE:- Been using this laptop for almost 18 months now and nothing has gone wrong till now.
I use proper activated antivirus and a firewall as well as a VPN when visiting sites .
My question is , is this actually water damage or something else , as the amount was water that I saw dripping out wasn't that much
Any help is appreciated guys.
Sorry, any water coming out is a BAD thing.
take it to a shop, it's probably damaged beyond your capability to repair it. you may want to buy a new laptop if the cost is high to repair it
Don't turn it on again, if u want to save it at all. Take it to a shop and go straight to the point and tell them water damage issue, can u fix how much, and ask them if they have an ultrasonic cleaner, they should.
If u have critical data to retrieve, make sure that's your first request, and u may attempt to DIY this if u know what you are doing.
