dimension 2400 with sound card
Jim
2,444
Archived from groups: alt.sys.pc-clone.dell (More info?)
If I order a 2400 with Dell's sound card (Sound Blaster Live! 5.1 (D)
Card) and use with a Hitachi Flat Panel (model: CML 175SXWB) I wonder
if the built in speakers will sound that much better with the sound
card ? Also if I don't get the sound card, how does the speakers in
the flat panel connect to the intergrated sound card on the Dell? If
I recall the Flat Panel has a cable hooking up the speakers to the
sound card.
David
2,039
Jim wrote in message news:<rf4lg09b6p2lesqsr74p0anft8omu4gaas@4ax.com>...
> sound card.
The integrated and separate sound card hook up to the speakers
exactly the same way. With the speakers you are talking about
I don't think it would make much difference either way.
You can always add a sound card later anyway.. Hope this helps.
Dave
G
Guest
Guest
The integrated sound card is quite good. For speakers in a monitor, the
integrated audio is better than that quality of the speakers. Even a decent
2.1 speaker set is good on the integrated audio.
Tom
<Jim> wrote in message news:rf4lg09b6p2lesqsr74p0anft8omu4gaas@4ax.com...
> sound card.
G
Guest
Guest
"David" <davids165@juno.com> wrote in message
news:4feda6e.0407301551.2fc24353@posting.google.com...
>> sound card.
> Dave
I agree. The speakers are the issue here and not the integrated or PCI
sound.
Stew
G
Guest
Guest
The built-in speakers will sound the same no matter what sound card you buy.
The speakers connect to your computer with a wire that comes with the
monitor, or you can buy one at Radio Shack for a dollar or two.
Ted Zieglar
formerly "Rocket J. Squirrel"
> sound card.
Jim
2,444
>sound card.
Thanks for the info guys. Appreciate your replies.
