Hi all,
I'm trying to fix a connection issue between two PCs.
They were connected via a crossover cable and the system worked, prior to updating one from Win10 to Win7 (User PC).
After this updating, they don't communicate anymore.
I can only access to one of them that is the user PC (and unfortunately i don't have admin permissions at moment). From this PC, i can see that the NW card gives this message "unidentified network", even after deactivating and activating.
The Win troubleshooter gives me a "unable to identify the problem" message so it is useless.
From this User PC, the IPv4 manual configuration is:
IPv4 address: 192.168.40.241
subnet mask: 255.255.255.0
def GW: blank
DNS server: blank
as it should be.
I've checked the drivers and are the most recent available. I've checked if network discovery is active and it is.
I've tried to connect them via a crossover cable and via a switch. In both cases, I have unidentified network on the user PC.
Consequently, if i try to ping the second one, it gives me this message:
Reply from x.x.x.x: destination host unreachable.
How could i fix this problem? Any suggestion?
Thank you very much for you time.
