Question directx 9 installation problem on WIN 10
Ojimoji
124
hi.
i just trying to install directx 9 cuz some old games dont run without that.
so i downloaded directx web installer from Microsoft .
and i receive this error while installation directx :
https://filestore.community.support...66d65-5352-469e-9f58-64747a65d5cc?upload=true
and i try offline installer of directx and RECEIVE SAME ERROR.
that error said Cryptographic must be enabled ,,, so yes it enabled in my windows.
so what can i do ?
my spec:
win 10- 64 bit v:1909 build:18363.418
please help.
Why my reply was deleted a few second ago?
I come here to get answer for this community .
Before i come here , i see another peoole have this exact problem about directx and same error .
And i see youtube vids about this problem, and noting help .
What is this ? Currupted directx?
Currupted system files?
What should i do?
Should i repaire windows with windows installation iso? How is that?
Are you sure it's directx they need? As mentioned in the post linked by onespeedbiker, you should have everything you need with the Windows 10 version of Directx. I ran the installer from the link in that post and it indeed said that there were no updates needed.
What error are you getting and with what games?
2 Errors :
xinput1_3.dll and d3dx9_43
In ( cod B ops 1)
So full story is : i install this win 10 about 2 months and i first install
Cod mw3 without instaling directx ,
And game run well , after i finish the game and unistalled , when i install this game (black ops 1) that error shows up .
You read my reply my friend?
Instalition directx and cryptographic service is my problem not this game .
Right now am not able run any game. On every gsme that error comes out.
Yes. But you need to understand that this is an older game and you need to jump a few hoops, at time, to get such games to work. Having said that, the Directx installer should run and say no updates needed, or something similar, so see if the AFC command recommended above comes up with anything.
i run sfc /scannow
and after complete< this massage shows up:
Windows Resource Protection found corrupt files but was unable to fix some of them.
For online repairs, details are included in the CBS log file located at
windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. For offline
repairs, details are included in the log file provided by the /OFFLOGFILE flag.
So first off, the reason your CBS.log is so huge is the number of language packs. If you need that many, fine. If you don't, remove all the ones not needed, delete the original CBS.log (or rename it to CBS.bak) and run the same sfc command. Will make it much easier to go through and see if there are any real errors here. I am still looking at your original CBS.log, but as it is so huge (as you noted) it may be difficult to find anything useful.
In summary, the results don't look back, but it would be great it you could remove unneeded language packs so that I could get a better look at it.
Your uptimes are a bit on the long side for me personally:
2019-12-21 06:33:50, Info CBS TI: Last boot time: 2019-12-06 19:16:36.500
I try to stay one week or less between reboots. While two weeks may not hurt anything, a clean boot could help in situations like this.
The actual summary of your last SFC doesn't look back though, but waiting for a cleaner file to be sure:
2020-01-04 06:57:34, Info CBS Summary:
2020-01-04 06:57:34, Info CBS Operation: Detect only
2020-01-04 06:57:34, Info CBS Operation result: 0x0
2020-01-04 06:57:34, Info CBS Last Successful Step: CSI store detection completes.
2020-01-04 06:57:34, Info CBS Total Detected Corruption: 0
2020-01-04 06:57:34, Info CBS CBS Manifest Corruption: 0
2020-01-04 06:57:34, Info CBS CBS Metadata Corruption: 0
2020-01-04 06:57:34, Info CBS CSI Manifest Corruption: 0
2020-01-04 06:57:34, Info CBS CSI Metadata Corruption: 0
2020-01-04 06:57:34, Info CBS CSI Payload Corruption: 0
2020-01-04 06:57:34, Info CBS Total Repaired Corruption: 0
2020-01-04 06:57:34, Info CBS CBS Manifest Repaired: 0
2020-01-04 06:57:34, Info CBS CSI Manifest Repaired: 0
2020-01-04 06:57:34, Info CBS CSI Payload Repaired: 0
2020-01-04 06:57:34, Info CBS CSI Store Metadata refreshed: True
2020-01-04 06:57:34, Info CBS Total Operation Time: 86 seconds.
2020-01-04 06:57:34, Info CBS Ensure CBS corruption flag is clear
2020-01-04 06:57:34, Info CBS Ensure WCP corruption flag is clear
2020-01-04 06:57:34, Info CBS All CSI corruption was fixed, ensure CorruptionDetectedDuringAcr is clear
2020-01-04 06:57:34, Info CBS Failed to clear CorruptionDetectedDuringAcr store corrupt flag (slow mode trigger). [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2020-01-04 06:57:34, Info CBS CheckSur: hrStatus: 0x0 [S_OK], download Result: 0x0 [S_OK]
2020-01-04 06:57:34, Info CBS Count of times corruption detected: 0
2020-01-04 06:57:34, Info CBS Seconds between initial corruption detections: -1
2020-01-04 06:57:34, Info CBS Seconds between corruption and repair: -1
2020-01-04 06:57:34, Info CBS Reboot mark cleared
2020-01-04 06:57:34, Info CBS Winlogon: Simplifying Winlogon CreateSession notifications
2020-01-04 06:57:34, Info CBS Winlogon: Deregistering for CreateSession notifications
2020-01-04 06:57:34, Info CBS Exec: Processing complete, session(Corruption Detecting): 30786222_3027027319 [HRESULT = 0x00000000 - S_OK]
