Question directx 9 installation problem on WIN 10
Ojimoji
124
hi.
i just trying to install directx 9 cuz some old games dont run without that.
so i downloaded directx web installer from Microsoft .
and i receive this error while installation directx :
https://filestore.community.support...66d65-5352-469e-9f58-64747a65d5cc?upload=true
and i try offline installer of directx and RECEIVE SAME ERROR.
that error said Cryptographic must be enabled ,,, so yes it enabled in my windows.
so what can i do ?
my spec:
win 10- 64 bit v:1909 build:18363.418
please help.
See if you have any better luck with this one.
https://answers.microsoft.com/en-us...g/b73c5fb8-12b6-493f-bc90-e8cc76fb842b?auth=1
which points to <Link removed by moderator>
<Moderator Note: Do NOT link directly to downloads. Link only to the page containing the download link>
You think my system file and directx are corrupted?
i run this 3 dism commands and this is results:
DISM /Online /Cleanup-Image /scanhealth
DISM /Online /Cleanup-Image /checkhealth
DISM /Online /Cleanup-Image /RestoreHealth.
and after that i run a Sfc /scannow and this result :
now what can i do?
please help.
I still don't see any errors. I know sfc says it couldn't fix some, but I have seen this posted on several systems where there is no major error.
A clean install is always an option. Bear in mind that this may or may not fix your directx installer issue, and may or may not fix your game's ability to run. As I mentioned before, focus on making the game work in Windows 10. Don't get hung up on Directx, which you already have.
The answer to this and most of these problems is format and reinstall
You do not need to install directx on windows 10. it has everything it needs. if you do it you’re screwing up your system
Uninstalling that first game you mentioned was probably screwing up your system
so what can i do?
i think you read my whole thread.
how fix cryptographic error during installation direct x?
yea i know clean install windows solve every problem such as my problem , but am here to ask you guys for fixing without reinstalling windows.
thanks
