DirectX Diagnostic Tool problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
When i am running dxdiag got this message
(Dxdiag has detected that may have been a problem accessing DirectInput the
last time this program was used. Would you like to bypass DirectInput this
time?)
and
(Dxdiag has detected that may have been a problem accessing DirectPlay the
last time this program was used. Would you like to bypass DirectPlay this
time?)
there is two option for me Yes or No if i hit No it i will reboot
automatically
Below i will attached my dxdiag info
I'm on WinXP HOME SP2 and DirectX 9.0C
Does anyone know what happen? Any suggestion?
Thanks in advance
DirectInput Devices
Poll w/ Interrupt: No
Registry: OK
USB Devices
Gameport Devices
PS/2 Devices
DirectPlay Service Providers
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result:
Registry: OK
DirectPlay Adapters
DirectPlay Voice Codecs
DirectPlay Lobbyable Apps
Usually that might happen if the video adapter is a marginal quality card,low
amount of memory,v.basic components,etc..Replace/upgrade card.This is with
having latest drivers installed,and with intel,one needs to have installed
the chip-
set installation utility,have those areas been met....
> time?)
> and
> time?)
> automatically
> Thanks in advance
> DirectInput Devices
> Registry: OK
> USB Devices
> Gameport Devices
> PS/2 Devices
> Registry: OK
> DirectPlay Adapters
