disk clean up and system restore
deb
98
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I get a message "the procedure entry point
RemoteAssistancePrepareSystemRestore could not be located in the dynamic link
library WINSTA.dll" when I try to do a restore point. Also, when I try to
run disk clean up, the process will start up showing scanning files, but
doesn't do anything but just sit there. It never does scan my computer.
What has happened to my system files and how do I correct it. I also got an
error message : "SRZ041011000114" Does anyone know what this is and what to
do about it? Thanks, Deb
Entry Point Not Found:
The procedure entry point RemoteAssistancePrepareSystemRestore could not be located
in the Dynamic Link Library winsta.dll
Do a search for the sr.inf file which is normally located in C:\windows. Make sure
you search hidden files in your search criteria.
Right-click on the sr.inf file and select the install option – you may need your
WinXP CD.
or
"Restore system restore services" #289
www.kellys-korner-xp.com/xp_tweaks.htm
Disk Cleanup Tool Stops Responding While Compressing Old Files
http://support.microsoft.com/default.aspx?scid=kb;en-us;812248
Disk Cleanup Utility Stops Responding
http://support.microsoft.com/default.aspx?scid=kb;en-us;812930
Why does Disk Cleanup freeze?
http://www.kellys-korner-xp.com/top10faqs.htm
Disk Cleanup - Compressed Old Files Freezes (Line 48)
http://www.kellys-korner-xp.com/xp_tweaks.htm
To use the Regedit: Save the REG File to your hard disk. Double click it and answer
yes to the import prompt. REG files can be viewed in Notepad by right clicking on the
file and selecting Edit.
Restore Disk Cleanup - cleanmgr (Line 84)
"Deb" <Deb@discussions.microsoft.com> wrote in message
news:C12F3206-BF93-40B9-852F-E5B7E3BD75E8@microsoft.com...
