Diskless Gaming Client Build HELP!
JC De Castro
33
Guys,
Can you please suggest a build for the above subject? I'm looking to make my own internet gaming cafe and I could use help in setting up a decent gaming build provided it falls under the ff requisites:
1. It must be inclusive of a monitor, mouse, keyboard and AVR.
2. If it CAN, it must be around USD300 or PHP20,000.
3. It must be able to play DOTA 2, LOL, HON, SF, CS.
Thanks in advance.
PS: I already have a server build in mind. I only need this.
CPU: AMD A8-7600 3.3GHz Quad-Core Processor ($77.99 @ SuperBiiz)
Motherboard: Gigabyte GA-F2A68HM-DS2H Micro ATX FM2+ Motherboard ($36.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 4GB (2 x 2GB) DDR3-1600 Memory ($35.99 @ Newegg)
Storage: Samsung Spinpoint F1 DT 160GB 3.5" 7200RPM Internal Hard Drive ($25.50 @ Amazon)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case ($22.99 @ Micro Center)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply ($19.99 @ Newegg)
Monitor: Acer V196WLb 60Hz 19.0" Monitor ($88.98 @ Directron)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($29.99 @ Micro Center)
Total: $338.42
Generated by PCPartPicker 2015-06-19 01:27 EDT-0400
Great. Just swap the STORAGE with a CPU COOLER then we're good to go. Thanks!
How come that's bad? I bet I can play all those games in low-medium settings. Let's see, if we exclude the STORAGE, it'll cost $312.92? Let us add an aftermarket cpu cooler, shall we? What do you say about a COOLER MASTER HYPER 212 EVO? MMm.. how do you post that pcpartpicker part list? LOL!
And a generic keyboard will do. LOL!
Why would you take out the storage? How are you going to store the games & OS?
And why would you buy a 212 EVO? It wouldn't help. Your processor is fine, just your graphics. The graphics is the problem.
You can run all those games at 30+ FPS, but that would be low settings, low resolution. It would be 720P at medium/low settings, around 40 FPS on counter-strike. It's not enjoyable. It's playable, but not enjoyable.
If you can spend another 100, you will see big differences.
'Cause this build is only a client build. I'm going to run things from a server. I don't need storage for that. Only the server has SEVERAL for that.
Regarding the CPU cooler, I just don't want the CPU/APU get hotter. I detest high temperatures. lol!
And yeah, that's only for 720p gaming at low-medium settings. A little tweaking and it could go to high. ^^
Thanks!
