Display : Color Problem on my Samsung Monitor
Reshmi
I have Samsung Samotron 55V, 14 inch color monitor which is about 4 years old.
Recently it does not display the colors as it should. I can’t describe the problem technically but it seems like it is missing the RED Color.
Blues and Yellows are OK and every thing else as far as display seems fine and I am able to use it pretty much like a Black and Blue Monitor.
I really don’t like to send in for a repair because most products it always comes back with more problems and new parts stolen and replaced with someone else’s used parts where I live.
If something minor needs to be adjusted, I would like to do it if someone can give me some guidance.
Thank You,
Reshmi
This could be caused by several things, so try these:
Reset the monitor to default settings using the onscreen controls.
Reset the Windows advanced video settings to default.
If the video cable detaches from the monitor try a different cable.
Try another monitor to insure it is not a problem with the video card.
If you get past all those then replace the monitor.
