Display Driver Problem
JamesJ
85
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi. I've recently been getting The Blue Screen of Death that
reports that nv4_disp.dll is the culprit. This is an NVIDIA display
driver: GeForce FX 5200. The system fails to start normally (freezes)
before it gets to the welcome screen. Using the xp Recovery Console
from the cd corrects the problem (takes about 15 mts using chkdsk /p
and I'm back in business, at least for a while.
This seems to have started about 2 weeks ago when I started using
Windowblind's Desktop manager. I applied a desktop and the system
automatically rebooted. (I have since changed the auto reboot setting.)
I went to NVIDIA's web site last week and installed the newest drive ( think
I got the right one) and after a couple days I got the BSOD. I then
installed
an older version of the drivers and it happened again.The knowledge base
at NVIDIA suggested updating the chipset drivers. I'm trying to cover all
bases
so How can I find I find out if I need to update the chipset drivers??
In the meantime I going to install the newest driver again and leave it even
if
I suspect it as the problem.
Any and all help will be appreciated.
Thanks,
James
You need to read the details about which chipset your motherboard is using
by check the manual or the manufacturer's web site. Then, you should locate
the correct chipset drivers.
However, you will need to do the following in order to correctly install the
nVidia video card drivers:
1) Locate, download, install and Liveupdate Driver Cleaner Pro.
2) Locate and download the latest nVidia card drivers (WHQL certified is
recommended!)
3) In Add/Remove Programs -- Uninstall the nVidia Drivers. DO NOT REBOOT.
4) Run Driver Cleaner Pro and select 'nVidia'. This will clear out the
left-over drivers files and settings. This is important since it is
possible that the files can cause conflicts if there are different version.
5) Reboot and let XP use the "default" video drivers it selects.
6) Then run the nVidia video card drivers install process and reboot.
"JamesJ" <jjy@adelphia_darwin.net> wrote in message
news:uuv3cNhsFHA.524@TK2MSFTNGP12.phx.gbl...
> think
> installed
> bases
> even if
> Thanks,
> James
If you think the problem started after you started using Windowblind's
Desktop Manager, did you try removing it?
Gary Tsang
Microsoft MVP - Windows XP Shell/User
http://www.microsoft.com/mvp
> think
> installed
> bases
> even if
> Thanks,
> James
> setting.) I went to NVIDIA's web site last week and installed the newest
> drive
> ( think I got the right one) and after a couple days I got the BSOD.
> I then installed
> base at NVIDIA suggested updating the chipset drivers. I'm trying to cover
> all bases
> it even if
> Thanks,
> James
It's caused by an incorrectly set clock. The zone is correct, but I bet
you've not checked the DST box. Do so, or you'll be killfiled by many.
I'll give it a shot. I probably didn't get all the old
driver removed when I uninstalled it.
Thanks,
James
"Yves Leclerc" <yvesleclercNOSPAM@sympatico.ca> wrote in message
news:%23lWhRUisFHA.760@TK2MSFTNGP14.phx.gbl...
> locate the correct chipset drivers.
> the nVidia video card drivers:
> recommended!)
> version.
>> think
>> installed
>> bases
>> even if
>> Thanks,
>> James
That's been long gone. In fact I don't normally go into
the registry but I attempted to remove every reference
to the software.
James
"Gary Tsang" <gtsangDELETE@MEaumha.org> wrote in message
news:eIct3ClsFHA.912@TK2MSFTNGP11.phx.gbl...
> Gary Tsang
>> think
>> installed
>> bases
>> even if
>> Thanks,
>> James
Used Driver Cleaner and Installed the lates nVidia drivers (WHQL certified)
Time will tell.
Thanks
James
news:OKBXerksFHA.996@TK2MSFTNGP14.phx.gbl...
> Thanks,
> James
>> using by check the manual or the manufacturer's web site. Then, you
>> should locate the correct chipset drivers.
>> recommended!)
>> REBOOT.
>> version.
>>> think
>>> installed
>>> all bases
>>> even if
>>> Thanks,
>>> James
Happened again. I'm not sure now if I should uninstall the
driver again or not. I used Recovery Console and I'm up and
running again, for how long I don't know.
James
news:e6%230%23klsFHA.3424@TK2MSFTNGP14.phx.gbl...
> certified)
> Time will tell.
> Thanks
> James
>> Thanks,
>> James
>>> recommended!)
>>> REBOOT.
>>> version.
>>>> ( think
>>>> installed
>>>> base
>>>> all bases
>>>> even if
>>>> Thanks,
>>>> James
All indicates everything is correct. DST is checked and
the my system time is correct.
James
"Miss Perspicacia Tick" <test@test.com> wrote in message
news:G28Te.8881$9T2.3163@fe12.ams...
>> drive
>> I then installed
>> cover
>> all bases
>> it even if
>> Thanks,
>> James
You're a day OFF.
> James
>>>drive
>>>I then installed
>>>cover
>>>all bases
>>>it even if
>>>Thanks,
>>>James
Yeah, your right.
Thanks
James
"Bob I" <birelan@yahoo.com> wrote in message
news:%23uqGxWusFHA.912@TK2MSFTNGP11.phx.gbl...
> You're a day OFF.
>> James
>>>>drive
>>>>I then installed
>>>>cover
>>>>all bases
>>>>it even if
>>>>Thanks,
>>>>James
You're welcome
JamesJ wrote:
> Yeah, your right.
> Thanks
> James
>>You're a day OFF.
>>>James
>>>>>drive
>>>>>I then installed
>>>>>cover
>>>>>all bases
>>>>>it even if
>>>>>Thanks,
>>>>>James
