Before we blame it on the ac adapter (and even if it's a bad adapter, it's probably not the only issue you're having...)
Here are some other things you can try (so we could eliminate things by trial and error)
To make sure it's not your video card :
-On the F8 menu at startup, can you see a VGA mode listed? if so, try that.
-If not, just go to safe mode and temporary disable your video card from Device manager. Try starting Windows normally again.
You're monitor is out of the question.
Battery and AC adpter:
-Temporary remove your battery, and try only runing on cable (ac adapter) and start windows normally.
-Remove cable and battery, hold power button for 1 min. Put only the cable back and start windows.
-And finally , try a different adapter...
U can also download (safe mode with networking) Speedfan so we can check the temperatures...
If I'll think of enything else, I'll let U know!
