Question Display won’t work?
TTVBTW
53
Today I built my first custom pc and when I turned it on, everything inside the case turned on and lit up but the monitor would not display anything and it said “NO SIGNAL”In my system I have :
Asus PRIME B450M-A
AMD Ryzen 5 2600x
2x Team Vulcan 8gb RAM 3000
RedDragon Radeon Vega 56
Asus PRIME B450M-A
AMD Ryzen 5 2600x
Did you make sure to plug the video cable into the GPU itself and not the motherboard? The 2600x doesn't have integrated graphics.
Yes I did, everything that is soppised to be plugged into the you in in. I was wondering if it might be the mobo.
It probably isn't. Let's rule out some more things.Try reseating GPU, unplugging and re-plugging cables (including the monitor's), using different displays if you have any. Can you tell if the system is POSTing? It doesn't beep or turn off by itself?
Okay, I will get back to you when that is done
