Greetings,
I built a computer with a Designare Z390 motherboard. I want to change to a multi display setup so one of my displays will be Display
Port, the other HDMI.
Both indeed work on HDMI, but neither are recognized when connected via DisplayPort.
This is what the manual says about the Onboard Graphics:
Maximum shared memory of 1 GB
Actual support may vary by CPU
THANK YOU IN ADVANCE FOR THE HELP!
- 2 x Intel® Thunderbolt™ 3 connectors (USB Type-C™ ports), supporting DisplayPort and Thunderbolt™ video outputs and a maximum resolution of 4096x2304@60 Hz
- Supports up to 7680x3840@60 Hz if connected to an external graphics card for display output.
- Because of the limited I/O resources of the PC architecture, the number of Thunderbolt™ devices that can be used is dependent on the number of the PCI Express devices being installed. (Refer to Chapter 1-7, "Back Panel Connectors," for more information.)
- Support for DisplayPort 1.2 version.
- 1 x HDMI port, supporting a maximum resolution of 4096x2160@30 Hz
* Support for HDMI 1.4 version and HDCP 2.2.
