Question dlink 2750U problem
Aug 2, 2022
4
I have a dlink 2750u v2 router with ME_1.16 firmware that has two problems:
  1. Low bandwidth of 3 megabits
  2. DNS settings are reset after an hour or after rebooting the router.
Aug 2, 2022
4
Is this the router you're working with? What firmware were you on prior to version 1.16? Try reflashing the firmware to one version prior and see if the issue persists.
Thank you for your answer, the same firmware was installed since the first day I bought the router, is it possible to downgrade to version 1.15?
Aug 2, 2022
4
If the firmware was on your router all along and you're experiencing issues with it now...after (assuming)years of use, then the router is on it's way out.
The router is not old, it has been bought for a year and it had the same problem from the first day.
Aug 2, 2022
4
If the problem persisted since day one of your using it, why didn't you seek a return or a replacement? You can try a firmware downgrade but your results can and will vary.
At first, I thought the problem was from the ISP side, but the problem was not solved even after changing the ISP.
