Dlink : "Access Point" or "Wireless Client" mode?
Alfie
4
Archived from groups: alt.internet.wireless,uk.telecom.broadband (More info?)
I have a wireless modem/router at home (Dlink DSL G604T) and a PC with an access point (DSL-2000AP+) hanging off it's ethernet port. There are a
couple of other PCs on the wireless network but they connect fine.
Do I configure the 2000AP+ as a "Wireless Client" or as an "Access Point" ? (It does bridging and something else too but that definately isn't it).
Confused,
Alfie.
> Confused,
> Alfie.
Short answer: "Yes"
Longer answer: You can configure it either way, with different results.
Most likely, you want to be able to reach your ADSL connection and/or the
other PCs in your wireless network. For that, set up the 2000AP+ as a
Wireless Client.
Roby
