So, I ordered a OCZ ModXStream Pro Power supply - 700 Watt for my power supply and I was hoping it is compatible with my motherboard, the ASRock Z68 Extreme3 Gen3.
The short answer is yes, but the long answer is no... not all mother boards and power supplies are compatible... but as a pc builder you're going to be dealing with ATX motherboards most of the time if not all the time... just make sure your power supply is ATX compliant. It will say so in the description at the store (most are...)
ATX12V and EPS12V Compatible Compatible with the ATX12V v2.2 and EPS12V standards, the OCZ ModXStream Pro OCZ700MXSP provides maximum power stability to drive the latest Intel and AMD processors as well as other components for desktop and server computer systems...
