[SOLVED] Do I need a Bluetooth adapter to connect headphones to PC?
Canyon Wireless Bluetooth Sporty Earphones BTH-1 (CNS-SBTHS1L)
Page link: https://canyon.eu/product/cns-sbths1l/
You will need to order a Bluetooth 4 USB adapter for your computer, as the earphones will work with most modern cellphones that already have Bluetooth, but not with a PC. Amazon has a ton of them. Bluetooth 4.1 (your earphones) will work with all Bluetooth 4 or 5 implementations (4.0, 4.1,4.2, 5) -- just be sure to get a newer adapter that has Windows 10 drivers. They run around $10 or so.
The Orica BTA-403 would be fine.
Check the details of your purchase, the headphones may come with a PC dongle. But in any case you will need a Bluetooth adapter on your PC, which it may have -- what is the model?
My headphone order and the description says nothing about an adapter.
Can you please elaborate that I may have an adapter on my PC? And when you ask what model, what are you referring to?
Some laptops come with Bluetooth build in with the wireless -- very few motherboards do though.
I'm on a PC and using an Ethernet cable, so that would be a no. In that case, I should order a Bluetooth Adapter?
Can you tell me if I should spend a bit of money of a simple 10$ adapter such as Orica BTA-403 will do just fine?
My motherboard model is Gigabyte H310M S2H 2.0
Thanks for your help.
Reactions: RealBeast
