Do I need a Fan for the Corsair Carbide SPEC-04 Case?
Azaren
48
Do I need to buy an extra fan for the Corsair Carbide SPEC-04 case? By the way, this is my build : https://pcpartpicker.com/user/Azaren/saved/KvPwP6
Also, if I need one, can you send me a cheap one that is good and that is in stock so I could buy it with the parts 😀 ? I also might overclock it to the max so think about that too if you can c:
Thanks & have a great day :) !
Won't be a problem, but two fans are quite enough. Or you could remove the included fan and use both the Sickleflow's instead. Your choice.
Since they're like really cheap, adding 2 won't be a problem for the case... I think?
MERGED QUESTION
Question from Azaren : "Do I need a Fan for the Corsair Carbide SPEC-04 Case?"
Regarding your build, you should really replace your hard drive with a toshiba or a western digital caviar blue, as the seagate barracuda is a big load of fail which will probably break on you. You should also get a cheaper mouse, and use the money you saved on the mouse for a better gpu or something. Just my 2 cents.
I just bought one fan (be quiet! Pure Wings 2) and my cpu (Ryzen 7 2700x) temp dropped at least 10°C.
currently, Pure Wings 2 is front intake and stock fan is rear exhaust.
I bought another Pure Wings 2 fan and plan for another front intake to get positive air pressure. I don't expect a significant drop in temp with the 3rd fan but I'll update once I get it.
