[SOLVED] Do I Need A Good Power Supply For My Graphics Card?
May 25, 2020
I bought an old prebuilt HP Compact 6300 SFF and I want to upgrade it. I want to put a graphics card in it but I'm not sure if my PSU will be able to power the graphics card. I have been planning to install a low profile Zotac GTX 1650 that doesn't need external power. I'm not sure what will happen when I boot my computer after installing the graphics card. My power supply is only 240 watts.
Intel Core i7-3770
Intel HD Graphics 4000
16gb DDR3 Ram
Hewlett-Packard 339A Motherboard
240gb SSD
Here is the power supply:
https://ibb.co/rw1Kqm2
https://ibb.co/9cpnzKG
Sorry I couldn't respond earlier
Oh.. noooo.... It's one of those proprietary, 12V Only with 12VSB HP PSU's With the funky fan that only has half blowing over the PSU!
Might as well just stick with what you got and see how it goes.
The only upgrade path from here is new motherboard, case and PSU.
Intel Core i7-3770
16gb DDR3 Ram
240gb SSD
The i7-3770 has 77W TDP and the GTX1050 has a 75W TDP so you should be fine.
I think you could even push to a GTX 1650 low profile like this one which I think is the biggest you can get without needing the PCIe power connector. It has the same 75W TDP.
I have an HP pro 6300 small form factor. that is about 5 months old. I would like to install a low profile GTX 1050. I am concerned that my power supply could possibly explode since it is only 240w.
The rest of the pc specs are -
i7-3770
240GB SATA SDD
1TB HDD 7200 RPM
microATX motherboard
16GB DDR3 RAM
Integrated Graphics
Will I be able to install a low profile gtx 1050 without my PSU exploding.
You need to start your thread. Removing previous messages from this thread.
