Do i need a UPS/Auto Voltage Regulator (AVR)/Line conditioner? (w/ specs)
PsychoFist
13
i wondering which one i should get? kind of on a budget so im trying to avoid the UPS if possible. my area does not experience a lot of outages but Murphy's law right? i just want to make sure my PC does't get fried, saving my work is a minor issue since i like to spam CTRL+S
specs are here:
http://pcpartpicker.com/user/PsychoFist/saved/1LGn
i really cant go much more cause im stretching my budget as is (in my area the total cost increased to around $150 more, no rebates)
The need for a power bar depends on your area, really. If you live in a place with non-constant voltage or frequent power outages, you need a power bar.
A UPS is just an extra component for convenience. It's never really necessary.
Get a power bar. The more joules of protection it states, the better.
your profile pic... it is AWESOME for answering questions! 😀
power bar? is that the same as a surge protector?
what wattage of AVR do i need? just the basic 500W?
You should be using the OPTI UPS SS2000 since you'll want to plug the monitor into it too along with any broadband modem and/or router.
I suggest shopping around because you can get the OPTI UPS SS2000 cheaper than what Newegg sells it for.
http://www.amazon.com/OPTI-UPS-AVR-SS2000-Automatic-Regulator/dp/B00305K3E0
FYI, you can buy a power bar that doesn't have any surge protection so a power bar is not the same thing as a surge protector.
Thanks 😀
As ko888 mentionned, I erroneously assimilated power bars to surge protectors. Thanks for the correction.
They look pretty much the same, but the power bar does not have a protection rating. The surge protector will have a protection rating measured in joules. The higher the rating, the better the surge protector.
You can get a pretty decent surge protector without needing to shell out a bunch of cash. If I were you, I'd definitely look into it!
