[SOLVED] Do I need RGB controller hub?
ajayphoenix
8
I am building a new desktop PC. I bought a case with no fans. So I am buying 6 thermaltake rgb fans, thermaltake aircooler with rgb fan and the case have an rgb lighting too. Do I need a RGB controller to synchronize all lighting.
Motherboard : MSI MPG B550 Gaming Plus(have mystic lighting option)
RAM : G.Skill Trident RGB
Case : Deepcool MATREXX 55 V3 ADD-RGB Middle Tower Computer Case
If yes I am thinking of buying phanteks rgb controller ( http://www.phanteks.com/PH-CTHUB_DRGB.html )
What do you think?
The "Rainbow" 3-pin headers are Addressable RGB (ARGB) connectors.
It looks like you're installing more than 8 lighting units and you only have two ARGB connectors and one RGB connector...so you need either splitters or a controller.
A controller has additional power (SATA) to run several units.
I suggest you make sure that all the lighting units are ARGB and compatible with MSI Mystic lighting.
If you want less cables on your case...then take a look at Lian Li RGB fans
https://www.lian-li.com/uni-fan
Reactions: ajayphoenix
Thanks man, I am buyng a RGB controller
