I want to have a i9-9900K With the MSI z390 gaming plus and a Power supply from Corsair CX650M bronze is it fine to use that power supply should I need to look for a power supply that is diffrent or isnt it so hard to look for a power supply
I use a 1060 6G gigabyte and the power supply self is black but there is indeed some Grey yesWhat about your GPU upgrade ? Which video card are you going to use on that setup ? This will also be a deciding factor, regarding the Wattage value. Anyways, that CXM model is an average unit. Not the very best Corsair sells, but it does the job ( Is it one of the older "Green unit" variants, or a "Grey unit" ?)
Maybe it sounds stupid but what are the EPS connections what do they doI would recommend something better than that, that's a low end PSU, not really suited for that system.
Something like the following:
Seasonic Focus Plus
EVGA G2
Corsair RMX
750W would be recommended due to the cabling options, having 2X EPS connections for the MB.
The 20+4 powers most of the mobo, but only has 2x 12v power leads, the rest being the minor rails, grounds etc. If you figure those 2x 12vDC leads are only good for a maximum of 60w each, and a cpu is somewhere around 75w or more, the gpu slots are 75w etc. Then there's a shortage of 12v to the motherboard in general. This is made up for by the EPS (extra power supply lol). A 4pin can add an extra 120w, an 8pin can add an extra 240w max. The i9-9900k can pull 200-250w in stock values, it scales up cores according to voltage (like a set of stairs) so not having suffient EPS supply means the cpu gets short changed and won't perform as it's expected to. Most mobo's designed with the i9-9900k as a primary consideration will have 1x 8pin EPS and a 4pin minimum or 6pin or second 8pin as well.
Your standard ATX psu only has a single 4+4pin EPS, it's not until you get to the 750w+ range that there's sufficient power to handle not only the i9-9900k but also the high end gpus that usually accompany such a powerful cpu. Very rare to see someone spend over $1000 on a mobo and cpu and slap in a gtx1050ti.
Even if a single EPS connector was insufficient in the OP's case (it's not), their motherboard only has one EPS connector (and no 4 pin ATX connectors).
I already linked to the molex mini fit jr. connector spec page. Feel free to check it yourself.Since when were pins rated at 6-7A? The wiring, sure, it's 18ga, but the pins themselves will only handle upto 5A. You try sticking 7A through any pin and you'll melt the connector.
You links cover wire sizes, not pins, wire length has nothing to do with the pin itself.A power or signal interconnect system rated up to 5.0A per circuit with standard brass terminals. Tough Nylon housings and robust terminal design create a durable, long lasting product. The Standard .062" products are reliable, economical and offer high value in features and price. These products are an excellent choice for power or signal interconnect applications.
chrome-extension://oemmndcbldboiebfnladdacbdfmadadm/https://www.intel.com/content/dam/www/public/us/en/documents/design-guides/resellers-power-supply-design-guide-changes.pdf+12 V Power Connector
Connector: Molex 0039012040 or equivalent.
Contact: Molex 44476-1112 (HCS) or equivalent (Mating motherboard connector is Molex 39-29-9042 or equivalent)
