Do I not have enough power for my GTX 1080?
JayTee3
163
Previously had a 1060 which had 8 pins
The 1080 duke has 8 pins + 6 pins
My PCI-E only has 8 pins
Help?
Looking at the front of the case, remove the right hand panel cover (that's the one in back of the motherboard). Psu should be visible.
As said, it's possible that there is extra wires still under there, if the psu has removable wires, they should have been given to you when you got the pc. Normally, with a 600w psu there should be at least 1 extra 6pin pcie, but I've seen 750w units that only have 1x 6pin pcie.
