Question do new case with fans help me to fix this prob !
kong6j
129
4
4,585
hello every one ihave question i play assassin's creed odyssey in high setting at 900p as you can see fan 61 percent and temp 81 and fan very noisy any advice ihave rx 580 xfx oc 1366 mhz idont have any fan in my box its simple case and my gpu xfx 580 have 2 fan if iplay fifa 20/19 temp max 62 so if If I buy new case will help me or just Waste money idont care about rgb only silence and temp thanks
View: https://imgur.com/Mma78mW
We're going to need more information.
First off, list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Then we're going to need to know what your ambient room air temps are. Is the same temps seen on other gaming titles? If so, name them.
FYI, throwing money at a problem you don't know what the problem is will only result in more money being flushed down the drain.
Reactions: kong6j
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
reyzen 2600x rx 580 dual fan xfx 1366 hdd 2tb ram 16 psu
Smart SE 530W - Thermaltake
