L loretojrcueto Prominent Dec 12, 2017 3 0 510 Dec 12, 2017 #1 mobo: A68HM-P33 AMD fm2+ will a 880k work for that mobo? im also going to upgrade to a 1050 ti
Solution Mark RM Dec 12, 2017 It is supported, but if you're going to pop it in, make sure you update the BIOS before you upgrade while the old CPU is still in it.
Mark RM Admirable Jul 16, 2014 2,658 1 7,960 Dec 12, 2017 Solution #2 It is supported, but if you're going to pop it in, make sure you update the BIOS before you upgrade while the old CPU is still in it. Upvote 0 Downvote Solution
L loretojrcueto Prominent Dec 12, 2017 3 0 510 Dec 12, 2017 #3 how do i update the bios? nvm i updated it Upvote 0 Downvote
