I currently own a build consisting mainly of
I7 9700K / z390 aorus pro wifi / RTX 2070 / 1 M2.nvme and 4 HDD's
They are running on an old Corsair TX 750 V2 , and it seems that it's fan ball bearings are in need of some lubrication as its producing an annoying chirping noise, the device is no longer under warranty. so my only options is to open it up and lube or swap the fan which will open the seal and diminish its price in the used market , or just sell it as it is and buy a new one.
The best options i have found available in my country were the Seasonic Focus Plus SSR the 1000w version and the 850w versions ? Price difference is around 30$ , i was wondering if I buy the 1000w version would it gurrantee a quiter system ?
