Hi, this may be a stupid question, but there goes. My computer case as lots of holes for fans (both 120mm and 140mm). If I only use inlet fans, surely the hot air has to be pushed out the other holes which have no fans, right?
The case only had one 120mm fan (an inlet fan on the lower front) and I have added two more 120mm inlet fans on the side panel as they are blowing onto the motherboard, cpu, gpu etc. The psu is at the lower back and sucks filtered air from underneath and exhausts it out the back, so doesn't act as an exhaust for the case.
The top panel has room for two fans and the top back can take another, the holes for these fans are quite large as I have removed the filters, so the way I see it the hot air will rise and go out them due to the positive pressure from the three inlet fans. Am I missing something here? Why do most people say you need as many exhaust fans as inlet? To me that's a waste of the fan's capacity. If they all act as inlets and the air can get out through the holes at the top, surely there will be a greater airflow, right?
