Question Does aim stabilization increase input lag on my monitor gigabyte g24f?
Mahir Niloy
36
I only play valorant and csgo.Is this a good option to have turned on for these games?Also theres a super resolution option in my monitor settings which increases sharpness.Does super resolution also increase input lag?I just got a gigabyte g24f and want to tune my monitor to best settings for competitive fps games like valorant.
I just got a Gigabyte G24F monitor and I want to tune it to best settings for competitive FPS games like Valorant.
I only play Valorant and CS:GO. Is it good to have "Aim Stabilization" turned on for these games?
Also theres a "Super Resolution" option in the monitor settings which increases sharpness. Does this also increase input lag ?
Yeah, it kinda does. Aim stabilizer is not really a good mode as it's a bad attempt of a backlight strobing mode. It disables brightness controls and makes everything have PWM artifacts.
I'd forget about using it altogether as the G24F already has insane anti-ghosting capabilities if you put Overdrive on Smart OD.
