Does copper brass or copper based radiator better for heat dissipation and silent operation?
bp8401363
226
I m looking for an all in one loop which will dissipate heat better than high end air coolers while producing low noise or even silent operation.
Thank you
-HH-
Dignified
Copper is the best for heat dissipation Followed by nickle.
That's solid material. Liquid cooling is al about flow of the liquid dissipation of the heat from the liquid. Copper is still the best material you can hope for otherwise. Are you going for an AIO cooler?
-HH-
Dignified
Kraken is a monster cooler, so are the other 2... I don't really like the aesthetics of the Raijntek stuff...
