I'm thinking of upgrading my PC, but I would like to use my own motherboard if possible. I have a GA-880GMA-USB3 (rev. 3.1). My question is: Will the FX-8350 work on the mobo? The 880G chipset supports it afaik, and it's an AM3+ socket, so I don't see why it wouldn't work. However, the supported CPU list does not list FX-8350, which makes me worry. Is it really not supported or is the supported CPU list not exhaustive?
http://www.gigabyte.us/support-downloads/cpu-support-popup.aspx?pid=3817
http://www.gigabyte.us/products/product-page.aspx?pid=3817#ov
