Question Does Gigabyte GC-CI22M_A CNVi WiFi Wireless-AC Upgrade kit support my motherboard?
No, the Wireless hardware requires the following socket:
Intel. CNVi interface 802.11a/b/g/n/ac, supporting 2.4/5 GHz Dual-Band (M.2 Socket 1, type 2230)
The motherboard does not have that. Though you can insert these CRF into a standard M.2 Key E socket, they are only compatible with a system designed for the CNVi.
The GC-CI22M_A is compatible with GIGABYTE motherboards of that include a CNVi slot on below:
Intel platform: H370-series, B360-series, H310-series
For example:
H370 HD3
Specifications shows it has
1 x M.2 Socket 1 connector for an Intel CNVi wireless module only (CNVI)
https://www.gigabyte.com/us/Motherboard/H370-HD3-rev-10/sp#sp
For example:
H370 HD3
if i insert it into the m.2 slot will it work
