Question Does I need to connect two CPU power cabel to my Mobo ?
Feb 11, 2025
29
I have CPU ( Ryzen 5 8400f ) and Motherboard ( Asus Tuf Gaming B850m-plus wifi )
My motherboard Has 2 CPU 12V power sockets
So i need to connect one CPU 12V cabel to mobo or 2 CPU 12V cabels ??
https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM5/TUF_GAMING_B850M-PLUS_WIFI/E24115_TUF_GAMING_B850M-PLUS_WIFI_EM_WEB.pdf?model=TUF GAMING B850M-PLUS WIFI
Page 1-2, turn your attention to the top left hand corner of the board, you should see 2x 8pin EPS connectors. The one labelled CPU_12V_1 is the connector that should be plugged in from the get go. If you plan to drop in a higher pedigree processor and wish to pursue a high overclock, then you connect CPU_12V_2 as well.
If your PSU has 2x8pin EPS harnesses, then by all means hook them up. Make and model of your PSU?
Moved thread from CPUs section to Motherboards section.
Latest posts
