[SOLVED] Does it matter which fan i'm using for pulling or pushing air out of the case?
The way the case is populated internally will have more to do with air flow than the position of the fans as long as they are working together, i.e. push/pull.
The only way to tell for sure is to try both configurations.
hm ok thanks, I just looked at the fans specifications and both of the fans are high-static pressure fans anyway so i should just pick the noctua to pull air in anyway
