[SOLVED] Does monitor native resolution affect fps
ohitsham
26
So I own a Samsung G9 and I play Warzone @ 1920x1080 or 2560x1440 not the 5120x1440.
I’ve been seeing people with same computer specs as me and they’re getting WAYY higher fps than me. But they own like 24 or 27inch monitors with native 1080 or 1440p. Am I losing fps Cus of my monitor or no.
Resolution absolutely affects frame rate. The higher it is, the harder it is on the GPU.
The G9 is a high end monitor and should be paired with a high end system for best results. Not only do you need a combination of high end parts, but also to be sure that they are performing the way they are designed. I echo @rgd1101 in regard to the spec and setup of you current PC.
yes but I’m not running it at 5120x1440p. I’m lowering the resolution to 1920x1080 or 2560x1440 instead to play. But doing this am I get the full FPS of similar monitors that are only 27”/24” 1080p/1440p
