Hi everyone.
I'm going to be putting in an order from Newegg soon, and I want some opinions on my main priority: My computer case.
Currently, I am running my computer in this case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146055
I have 2 scythe 120mm fans on the side blowing air in towards the CPU and GPU (Both fans push 110cfm of air).
I replaced the front fan with another 120mm scythe fan (110cfm) and it's pushing air towards the back (sucking air from the front).
I also have a fan pushing air out the back.
I was thinking about upgrading to this case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146047
My main concern is heat. My room gets way too hot for my likings (I love the cold air).
So, if I upgraded, do you think it would lower my temperatures? My CPU idles at 25 celcius, and my GPU at ~50 celcius in my current case.
Is it worth the extra $100? If not, what could I do to keep my current case cool?
Sorry if I'm vague, I'm just typing this as I think of it. =/
Thanks all.
Thanks all.
