Very well balanced with the 1300x and 1050ti, good quality parts and you didn't skimp on the psu! Yeay!
Looks good. Optical drive is an option now, windows 10 comes on USB stick, so possibly save a few bucks there unless you want it.
The Ryzen cpus love fast memory, it's a cheap (upto @20% performance gain) just moving from 2133 to 2666, so that's a consideration. I'd recommend g-skill Trident-Z, RipJaws V or Flare X
