K Kahhhexe May 12, 2020 7 0 20 May 14, 2020 #1 Hi all, I just bouth a new mother board and a new kit of memory. Does this kit is compatible with my motherboard? RAM: 2x8GB HX426C16FB3/8 8GB 1G x 64-Bit DDR4 2666 CL16 288 Pi DIMM MB: GIGABYTE GA-a320m-s2h thanks,
Solution K K Kahhhexe May 15, 2020 Hi, Problem solved. I dinabled the bios option "Core booster" and reset my win10 No BSOD thanks,
S SamirD Judicious Jan 16, 2014 6,608 953 35,940 May 14, 2020 #2 Check your motherboard qvl here: https://download.gigabyte.com/FileList/Memory/mb_memory_a320m-s2h_bristol.pdf Upvote 0 Downvote
K Kahhhexe May 12, 2020 7 0 20 May 14, 2020 #3 Hi, I didn't find the memory code in the list (HX426C16FB3/8), but when I turn on the computer it works but it got some BSOD. errors: driver irql not less or equal irql not less or equal thanks Upvote 0 Downvote
K Kahhhexe May 12, 2020 7 0 20 May 14, 2020 #4 My setup: RAM: 2x8GB HX426C16FB3/8 8GB 1G x 64-Bit DDR4 2666 CL16 288 Pi DIMM MB: GIGABYTE GA-a320m-s2h GPU: Galax gtx 1060 6gb exoc white PSU: Corsair 850W CPU: Razer 5 3600x SSD: SSD Kingston 120GB Upvote 0 Downvote
K Kahhhexe May 12, 2020 7 0 20 May 14, 2020 #5 This is the minidump files I've got yesterday: 1º BSOD IRQL_NOT_LESS_OR_EQUALntoskrnl.exe ntoskrnl.exe ntoskrnl.exe+1c2390 2º BSOD IRQL_NOT_LESS_OR_EQUAL ntoskrnl.exe ntoskrnl.exe+1c2390 3º BSOD DRIVER_IRQL_NOT_LESS_OR_EQUAL ntoskrnl.exe ntoskrnl.exe+1c2390 4º BSOD SYSTEM_SERVICE_EXCEPTION ntoskrnl.exe ntoskrnl.exe+1bc810 Thanks, Upvote 0 Downvote
K Kahhhexe May 12, 2020 7 0 20 May 15, 2020 Solution #6 Hi, Problem solved. I dinabled the bios option "Core booster" and reset my win10 No BSOD thanks, Upvote 0 Downvote Solution
