Does power limit change anything?
Perfectly fine to raise power limit, just allows your graphics card to boost higher really. 😉
No risk of damage unless you have a faulty card, the graphics card's BIOS will be equipped to handle the additional power easily.
If it isn't equipped to handle the extra wattage, the option simply wouldn't be there, as the manufacturer is held accountable for faults.
