Question Does Ryzen 5 8400f require Thermal Paste
To clarify, there must ALWAYS be thermal paste. On a new cpu, typically a stock cooler will have it on the bottom of the cooler. If you buy an aftermarket cooler that doesn’t have it on there, then you need to apply it. I typically put a small dot in the center and use my finger to spread a thin layer. Others do it different but that method has worked for years for me.
Reactions: CountMike
