Pc Specs
Mobo: Asus tuf b450 tuf
Cpu : Amd Ryzen 3600
GPU : Msi 2070 Super
Psu : 650w (Forget Name)
Ram : 2x8 Corsair 3200
Have had comp for about 3 months now. Went into Bios saw my ram was at 2133mhz, so i set it DCIOP Profile 1, which was 3200mhz
Computer Worked fine then the next morning woulnt post, Led's Fan and everything turned on than stayed at max speed
Reset the bios Via Removing battery for 1 min - No Change
Did it again but waited 7 min - No change
Did it again but also used a screwdriver to connect the 2 CMOS jumper pins together - Note Psu was off, everything unpluged Gpu out (left ram in) Forgot to hold power button for 20 sec after unplugg, but it was unplugged for at least 20 min before i started doing anything.
Now pc wont boot, no fans or case led. Only sign of power Is the RGB on the Msi Super
Think I already know the problem to be a fried MOBO. Hopefully this inst the case thou
Also No Beeps From Computer, dont have speekers, but plugged my headset in
