[SOLVED] DP Cable / USB cable pin or tip grounding ?
mark_07
28
Hello, I'm not sure if I'm using the proper wording, but when I touch or accidentally touch the pin or the tip of my DP cable or a usb cord, I get a zap of electricity which really kind of hurts. Is this normal or do I have a grounding issue ?
Currently both both PC and the usb cord (for external hdd) is on a shelf, do I need to have the cable touch the ground or wall? Please help
dwd999
Do you live in a desert or low humidity climate? I do; that's just static electricity that your clothing generates as you move around. What kind of outside and inside humidity readings to you have?
Reactions: mark_07
dwd999
Reactions: mark_07
mark_07
28
Oh right, it could be the humidity as its pretty hot in here, I live in the South East Asia. So its just normal and will not really do any damage to the devices right. Thank you for responding dwd999, I appreciate that
dwd999
There are various ways to mitigate static electricity depending on your situation. There are wrist straps that you don't have to wear; you could just touch the metallic part when you sit down at your desk. Or mats that you could place on your desk underneath your keyboard area that you could touch when you sit down.
