Hello Everyone i have some dram issues that i would like some help to so my problem is that i have 4 sticks of ram and before installing the new GPU that i have bought all 4 were working perfectly fine and now after i have installed the GPU i can only put 1 stick in and saddly i cant find out why is that there and i have inspected for maybe a broken pin or somethink at ram slots but no thats not the problem everythink is oke i have tested every ram stick by itself and all of them boot up but if i trye the second ram stick it doesnt work and yes i know where i should put the sticks in if iam using 2 of them i have read the manual and i took down the CPU Cooler down to see if maybe it is related with CPU and there is no broken/bented pins or somethink i even lossen the CPU Cooler down a bit to see if it maybe works but it doesnt work saddly is there a way to tell me what to do to get them to work because iam struggling here saddly and there is nothink visually wrong with CPU or with Ram slots/sticks or with somethink else i have tested everythink that it is possible for it to check and it still doesnt work Does anyone think for an idea whats causing it
i builded the system by myself
MotherBoard : ASUS Tuf Gaming x570 Plus
CPU : Ryzen 5 3400g
GPU : Rtx 3060
CPU Cooler : DeepCool AK620
RAM Sticks : Corsair Vengeance 2x8GB 4.24Version and 2x8GB Version 5.39 (and version is not a problem before they all worked fine)
CPU : Ryzen 5 3400g
GPU : Rtx 3060
