Archived from groups: microsoft.public.windowsxp.customize (
More info?)
Thanks Stan. Fixed the typo.
>> TweakUI solution is not available to limited users
Yup. Hence the manual registry edit suggested at the bottom of the page.
Ramesh, Microsoft MVP
Windows XP Shell/User
http://windowsxp.mvps.org
> On Thu, 15 Sep 2005 10:32:43 +0530 in
> microsoft.public.windowsxp.customize, Ramesh, MS-MVP favored us
> with...
>> You may want to remove the tip on your site regarding
>> "NoDrivesInSendToMenu", Stan. This is not valid in Windows XP, afaik.
> After considerable experimentation,[1] I agree with you, and I thank
> you for the correction. I have updated
http://oakroadsystems.com/tech/winxptip.htm#ContextSendto
> and would appreciate comments on the revised version.
> I'm also able to return the favor.
🙂 On your page
> <http://windowsxp.mvps.org/nodrives.htm> you might want to note that
> the TweakUI solution is not available to limited users, only
> administrators, and also that it won't affect any other users. So
> folks who are importing registry keys need to do so for every user.
> Also there's a typo in the first paragraph, "fore" instead of "for".
> [1] I tried under HKLM as well as HKCU; I tried NoDriveInSendToMenu,
> NoDrivesSendTo, etc. I also tried bit-masking the registry value, as
> is done for the Autorun setting. Nothing had any effect, even though
> I loggged off and on again after each registry change. So either the
> advice I quoted[2] was just dreamt up out of whole cloth, or there's
> some variation of the value that I was unable to guess.
> [2] The incorrect advice I used to give is pretty common on the Web:
http://groups.google.co.uk/groups?selm=uduWClqHFHA.3472@TK2MSFTNGP09.phx.gbl
> and this answer at Microsoft seems to agree with
http://www.microsoft.com/windowsxp/expertzone/chats/transcripts/04august24.mspx
> and so do
http://episteme.arstechnica.com/groupee/forums/a/tpc/f/99609816/m/248009684731
http://www.eggheadcafe.com/ng/microsoft.public.platformsdk.ui_shell/post20316652.asp
> and others.
> "To put it bluntly but fairly, anyone today who doubts that the
> variety of life on this planet was produced by a process of
> evolution is simply ignorant -- inexcusably ignorant, in a world
> where three out of four people have learned to read and write."
> --Daniel Dennett, /Darwin's Dangerous Idea/ (1995), page 46
